Mitsubishi FG25N:
Mast won't lower
I have a FG25N that the mast won't lower on. It happened out of the blue with no symptoms leading up to it. It will raise and tilt forward and back, just won't lower.
I noticed on the valve control body, there appears to be an electronically actuated valve; is that some form of safety mechanism that allows the lowering of the mast? If so, if that goes bad will that stop the mast from lowering? Is there any kind of override to lower the mast, without cracking a line and making a mess?
  • Posted 1 Aug 2023 04:13
  • Discussion started by 4klift
Hy
First check for broken rollers ot istn the cart is too tight
Try to change joysticks tilt/lift
Try to change the cabels for the magnets on lifting upper to lower and lower to upper. It should works revers.
Sorry bad englissh four
Dubuque, IA, United States
Louisville, KY, United States
