Mast tilt creep
I have a Cat P5000 and the tilt creeps forward. I resealed the cylinders but it didn't help.
Is there a counterbalance or holding valve in the tilt valve assy.
I have no manual for this machine so any help I can get will be welcome.
Thanks, Bob T.
I originally posted this in the wrong place I believe.
  • Posted 16 Aug 2012 03:09
  • By BobT
  • joined 16 Aug'12 - 3 messages
It does creep with the key off. However I have pressurized both cylinders on the bench with one port open. They do not pass any oil in either direction. I guess the spool in the control valve must be allowing oil through when centered or I have a weak return spring.
I guess it's tear down time.
Thanks for the reply.
  • Posted 17 Aug 2012 00:49
  • By BobT
Does it still creep if you turn the key off?
if so, you have bad repacking of the cylinders. if not, it most likely will be in the valve.
This unit has a holding setup that when the operator is not in proper position to drive the truck, or the motor is not running, that will lock the hydraulics and not allow motion, and this setup is part of the main hydraulic control valve.
  • Posted 16 Aug 2012 19:57
Mitsubishi Logisnext FD25T5M
Nagano NUL120-6
Philadephia, PA, United States
Chandler, United States
Steve Nation Steve Nation
Senior solutions sales engineer, Numina Group
President, International Federation of Robotics
VP of Corporate Remarketing, Alta Material Handling
Chief executive officer, Peak Technologies
Nagano NUL120-6
ATEX MIRETTI GROUP
Miretti Explosion Proof Systems for Material Handling: for over 50 years, "Ex Atex Safety in Explosive & Hazardous Areas".
ATEX MIRETTI GROUP
