Losing trans pressure
I had the trans(2 sp F,2 sp R) on this truck rebuilt by a trans rebuilder. After installing it, I had to crack a line to get the fluid flowing flowing.Once this is done, the truck works fine. After shutting it off and it sitting 10 or so mins, it seems ti lose prime. I have to rev it for 3-4 secs or so in gear, and then it will go. Leaving it sit overnight-and I have to crack a line again. Pulled trans and sent it back- rebuilder says it checked fine and they tested it 3 or 4 times with no problem. Put it back in and i have the same problem. Anyone ever run into this? Am I doing something wrong? Thanks in advance
  • Posted 27 Jun 2008 03:27
  • By joe_g
  • joined 15 Sep'07 - 10 messages
  • New Jersey, United States
Thanks for the reply. I had the rebuilder finally install a new pump, after I found out that rebulders will not put a new one in due to the high cost. Solved the problem.
  • Posted 17 Sep 2008 23:41
  • By joe_g
Ive got this problem as we speak.A colegue has recently rebuilt the transmission,new plates,seals ect ,but he never renewed the pump??? got one on order.Bet it drives after.
  • Posted 16 Sep 2008 08:47
  • By tugmaster
  • joined 25 Aug'08 - 73 messages
  • United Kingdom
Have seen this issue before. The trans pump looks good inside, but it is bad. Replace it.
  • Posted 16 Sep 2008 02:47
  • By Jeff
  • joined 8 Feb'07 - 61 messages
There is nothing worse than a sharp image of a fuzzy concept.
-Ansel Adams
Terberg RT223
Terberg RT403
Terberg RT223
Terberg RT403
September 8-9, 2026 - Barcelona, Spain
November 11-12, 2026 - London, United Kingdom
February 8-10, 2027 - Mumbai, India
Fishermen in the town of Oostduinkerke on the western tip of Belgium's coast practice a 500-year-old form of shrimp fishing. Known as paardenvisser, the fishermen trawl the shallow waters on Brabant draft horses, pulling funnel-shaped nets to capture the crustaceans.
