Looking for a carburetor on an old Yale
Hi guys first post here ran across this site off a Google search and hoping you can help. I have acquired an old Yale lift that needs a carburetor. I know the lift ran previously and the owner had carbs problems and took it off and between business closings and bankruptcy it is Mia. I seen an old post that looks like what I need but I have had no luck finding anything online or at dealers. This is the old post and the ebay link shows a carb that looks right. https://www.forkliftaction.com/forum/help-me-identify-this-carb.aspx?t=16979. Can any one help me out here. The model is GTP050rbjuat080 ser. P3I4732. I am looking for a gasoline only carb. It originally had a dual fuel system. I believe it is a Mazda ua engine. Thanks guys.
  • Posted 13 Feb 2024 04:43
  • By Justin_Miller
  • joined 13 Feb'24 - 1 message
  • Iowa, United States
I read your post you said it was duel fuel why dont you run it on propane first you cant run gas inside a building and second the truck moter will last alot longer on propane than gas gas will wash the rings out and the engine will start smoking and also if set up on propane correctly it will burn a lot cleaner than gas. This is only my opinion
  • Posted 26 Feb 2024 03:53
  • By Scott_
Scott
Justin,
Not able to locate a new or used carb. You will need to find an old scrap lift or find something off an older car that may fit. Good Luck.
  • Posted 20 Feb 2024 03:13
  • By Fishmech
  • Virginia, United States
