Linde serial canbox not connecting
Hi
I have installed pathfinder and truck doctor which both do not work when connected with canbox - doctor works when connected to 335 etc ( no can box required ) and pathfinder works with engine cable connected - again no can box required. It seems that it is not seeing the canbox connection - any help would be much appreciated
  • Posted 6 Apr 2018 22:54
  • By chris_e
  • joined 6 Apr'18 - 12 messages
  • Essex, United Kingdom
We can fix this issue by remotely by Teamviewer
  • Posted 10 Aug 2025 01:08
  • By Dil_Era
  • joined 30 Jun'25 - 35 messages
dilshanrandeep@gmail.com
teamviewer just kicked me off
  • Posted 18 Apr 2018 05:20
  • By Lindetech
  • joined 27 Mar'16 - 131 messages
  • Auckalnd, New Zealand
email has been removed
don't know why
  • Posted 18 Apr 2018 05:06
  • By Lindetech
It seems url has been removed so
Id 731 385 398
Pass 7397
  • By chris_e
[email address removed]
  • Posted 18 Apr 2018 05:05
  • By chris_e
What's yours the I can send u one?
  • Posted 18 Apr 2018 04:47
  • By Lindetech
Hi have you an e mail I can send teamviewer id to rather than give details on forum
  • Posted 18 Apr 2018 01:12
  • By chris_e
No you don't need to connect to truck
Just internet and let me know when your on and the team viewer number
  • Posted 17 Apr 2018 18:12
  • By Lindetech
Hi
Yes, but am on a days hols today - so no laptop - do I need to connect to truck before going on teamviewer to yourself
  • Posted 13 Apr 2018 23:20
  • By chris_e
You have teamviewer on laptop?
  • Posted 13 Apr 2018 22:40
  • By Lindetech
Thanks
I am using a serial canbox, will check the configand adjust as necessary. I have been told that canbox might need to be flashed - have no idea what this is or how to do it.
Thanks again
  • Posted 13 Apr 2018 06:04
  • By chris_e
what can box are you using?
serial or usb?
you need to configure it for using the correct canbox
computer/localdrive/linde mh/pathfinder/doiamon31/data/cps/configuration
dtr and rts need to be set to 0 for usb and 1 for serial
  • Posted 13 Apr 2018 05:34
  • By Lindetech
Thanks, I am not I T minded - where will I find this config file
  • Posted 7 Apr 2018 18:28
  • By chris_e
look ad you config file of phatfinder
  • Posted 7 Apr 2018 17:28
  • By michel_v
  • noord holland, Netherlands
