LINDE R20 ser115 dc
HI all,
I wonder if someone could help me with this issue:
Reach truck just to operate the hydraulic controls displays error "E-boot" and hydraulics functions are disable. Traction is ok.
Please, any ideas?.
Thanks in advance.
Best regards
  • Posted 26 May 2012 04:37
  • Modified 26 May 2012 04:37 by poster
  • By nacsand_n
  • joined 20 Sep'09 - 716 messages
  • Madrid, Spain
Thanks for reply Michel v,
Yes, I wrote them but have not the list here, I checked faults in LLC and LDC modules and showed several faults in both modules.
Remember any faults in LLC related to reach solenoids, joysticks not in netral position, 15v supply joysticks etc.. Makes me think in LLC module, hope to solve it soon because is making me crazy.
Let me tell you more tomorrow.
Thanks a lot
Regards
  • Posted 29 May 2012 06:28
  • By nacsand_n
  • Madrid, Spain
can you foud s code from reading?
  • Posted 28 May 2012 17:14
  • By michel_v
  • noord holland, Netherlands
Please, any more ideas or suggestions?
Thanks in advance.
Regards
  • Posted 28 May 2012 03:29
  • By nacsand_n
  • Madrid, Spain
Yes, I know it about prompts you indicate, but in this case the prompt is "E-boot" that is not indicated in service manual.
Have been checked battery, hydraulic levers, solenoids and wires, all related with hydraulic system and have found nothing unusual.
Is an intermittent fault and I'm thinking about LLC module fault.
Thanks for help.
Regards
  • Posted 27 May 2012 08:38
  • By nacsand_n
  • Madrid, Spain
nacsand n;
You are seeing one of the HELP prompts. These are a series of prompts that may appear on the Meter Panel Display if a function, such as lift or traction, is being interlocked. The prompt will only appear as the function is being operated and will only cover the basic interlock of the truck.
The prompts that come close to the one you are showing are:
L,boot - The Lift controller failed it's power on self test or
the battery is flat
T,boot - The Traction controller failed it's power on self test
L,Foot - On a single pedal truck, the left foot switch isn't
operated
  • Posted 27 May 2012 07:53
  • By MEngr
  • Missouri, United States
Thanks for reply MEngr,
Yes it is equipped with LES, with brushless motor, controller and gear box integrated, but found that steer and traction functions are Ok and only hidraulics functions are disabled when displays the message.
Thank a lot
Regards
  • Posted 27 May 2012 03:55
  • By nacsand_n
  • Madrid, Spain
nacsand n;
Is the rolling reach equipped with Linde Electronic Steering (LES) ?
  • Posted 26 May 2012 10:18
  • By MEngr
Deborah Baker Deborah Baker
Muncie, IN, United States
UN Forklift FD15-18T
Toyota 02-8FD30
