linde H40T S/N 352H heating problem.
How a hydrostatic transmission can cause heating?. Im suspecting it can be, truck engine heats in about 2 to 3 hr of operation. Work done:
-head gasket changeg, valves and seats grinded, dimentions verified, inspection of pistons and liners (look fine). timing gear possition ok, power mixture and cooling system double checked.
Any information or advise how to make basic ckecks. on this transmssion will be greatly appreciated.
Tanks
  • Posted 6 May 2010 01:54
  • By roldann
  • joined 3 Sep'08 - 86 messages
  • nuevo leon, Mexico
Hello,Mr.Roldann.if there is a hydroulic pump on fan, check whether the oil from the pump.if leaking, then replace Radial shaft seal
  • Posted 13 Jun 2010 20:00
  • By tabak
  • joined 31 Mar'08 - 39 messages
  • nas. Karpos, Macedonia, The Former Yugoslav Republic Of
tabak_08@hotmail.com
You should check the model # of the engine. Linde used the 4.236 for a short while and then changed to a 1004.40S.
I have never heard of one of the series trucks overheating. They typically run very cool. I'm wondering if something in the hydrostatic drive system is taxing the engine and causing it to overheat.
  • Posted 10 May 2010 22:05
  • By duodeluxe
  • United States
duodeluxe
thanks, andrea:
right now it was removed, it did no much difference when installed. Also the perkins 4.236 is the Original engine?
  • Posted 10 May 2010 08:57
  • By roldann
also the thermostat is ok?
  • Posted 9 May 2010 20:37
  • By andrea_g
  • joined 16 Apr'10 - 15 messages
  • roma, Italy
hi, andrea. The cooling system it´s been double checked. new radiator and water pump were installed an refilled with antifreeze
  • Posted 9 May 2010 09:55
  • By roldann
hi, Michel. The heating is in engine or at least it is reflected in engine.
  • Posted 9 May 2010 09:52
  • By roldann
check the radiator, where the water circulates. If the person concerned is not never put antifreeze, the steps may be clogged.
  • Posted 8 May 2010 05:53
  • By andrea_g
  • roma, Italy
de haeting problem it is in engen ore in hydrolick oil ?
  • Posted 8 May 2010 01:36
  • By michel_v
  • noord holland, Netherlands
Taylor T650L
Terberg YT222
Taylor T650L
Terberg YT222
