Linde h30t firing problem
Hello,
Linde H30t lpg with the vw bef engine. Recently had the cam sieze which broke the cam belt. Having had a full head re-biuld etc ran fine for about 10 mins then spluttered and stopped. Now, doesn't want to fire. It seems to only be firing on cylinders 3 and four and not randomly. Compression test absolutely fine and all four plugs have spark. Also timing hasn't jumped still spot on. Therefore we have assumed this isn't related to the recent rebuild.
Is there a way to check error codes on this truck as nothing comes up on the display. Any other suggestions as to what might be causing this.
We did wonder if oil gallery's to the head may be blocked but normal compression readings show valves to be opening as they should?
Thanks in advance.
  • Posted 22 Mar 2019 00:27
  • By Chllinde
  • joined 22 Mar'19 - 1 message
  • United Kingdom
Hoist Liftruck F180-36BOX-CAR
UN Forklift FBRP15NQZ2
Noblelift
edition #1240 - 24 July 2025
CeMAT Australia 2025 has been underway in Sydney this week, wrapping up today, with the main topics coming out of the event proving to be the very predictable automation and sustainability... Continue reading
