hello i have a linde h25t, h2x392p00281 from 2003, i need to install a reverse horn( beep beep), but my forklift only has two lights in the front and only one switch in the panel, in the back has no light, and i do not know where to connect the reverse horn , i looked at the fusses but i didn't find any one for reverse.
please help!
thank you very much , i finally did it.
my german is a bit rusty but if i read the wiring diagram right on the central control panel behind the seat relay 4 is the reversing relay , Fuse 21.3 (4F1) 10A fuse is reversing fuse and also there should be a 6pin connector 4X2 that should have the reversing signal where you can tap.
check it with a meter and see if i'm correct.
you can also look around the rear of the truck in the counterweight or along the side panels and see if there are any unused connectors or accessories and check those with a meter, when selecting in reverse you would get voltage on it.
sent one mail to my mail adres
it is on profile
Can i get the signal from a pin of the computer and then pased it to a reley, with pin do i have to conectat?
you can make it yourself, the job in the coputer???????
This is the only way ?
i need to buy the look?
you hef to order one loon for backup alarm3923810327
