Hi, i have a linde e16 324 serie and have steering and lifting hydraulics but no traction.
contactors oke but not come in. potentio meter pedal oke. The fan from the traction motors blowing continue. I have no fault code with the handset and there are no indicator lamps flash on the dashbord or faultcode
I can't find the problem. At last i cut the loom from the back to the steering wheel and find it!
They have two lamps on the mast and they have make the + from the contactkey and the negative from the bleu cable! This is very bad and i seen the loom as one melted cable. I have fixed the problem and make new cables and remove the lamps. The truck working now perfect.
Hi, I have the same issue on a unit I'm working on. My model is an E15 324 series. Same exact problem.
What did you find? Unfortunately I could not understand the language from the other replies.
Can you tell me if you found the problem and if so, What was the issue?
de electronica is zo beveiligt dat hij niet werkt zo gouw hij merkt dat er iets niet goed is
macht je nog wat nodig hebben mail me maar even op hotmail
Hoi Michel,
Al zou er sluiting in een rijmotor opgetreden zijn springt er dan geen zekering uit? Of raakt de controller niet defect. Ik ga de motoren nameten en hoop dat ik de oorzaak vind
groeten
dit is een probleem van je koolborstel bewaking of temp senders van je rijmotors
of sluiting in rijmotor
groetjes michel
