junheinrich etv 216 error 19 &70
Error 19, info 22, and error 70 on dash. 2006 ac truck. Steer controller and brake mfc test good. Im thinkink traction controller. Any info would be great,
Thanks
  • Posted 17 Feb 2013 05:51
  • Discussion started by diesel123
  • antrim, United Kingdom
Hello!
we meet with this errors in ETV214 2008y.
after replacement of controller errors gone
  • Posted 21 Feb 2022 19:20
  • Reply by Sergmal90
  • Russia, Russia
with kind regard
SergMal
smal-90@mail.ru
Yes Danny I understand what you mean now, my traction controller was definitely faulty, i tested it in another truck. After replacing the traction controller I am getting error 115(steering contactor), I have ruled out steering controller and contactor, is it possible the fault can be coming from my hyd controller?? Thanks
  • Posted 19 Feb 2013 03:31
  • Reply by diesel123
The motor has an encoder to give positioning feed back to the controler, on jungheinrich machines it is part of one of the motor bearings. This is an ac truck isn't it?
  • Posted 18 Feb 2013 07:38
  • Reply by danny_k
Thanks guys. Danny what do you mean by motor encoder?
  • Posted 18 Feb 2013 03:17
I would check the motor encoder first as they are quite common on these and it's the cheaper of the 2 options.
  • Posted 17 Feb 2013 19:21
  • Reply by danny_k
Probably bad controller,
19-Disable armature faulty;
Power stage short circuit
(for AC)
The error may be
triggered by the faulty
speed sensor in
connection with
AS4814Plus controllers.
Sensor wheel wobbles
(elliptical) or the sensorsensor
wheel gap is too
big. In this case the
component is not faulty.
A short circuit cannot be
resolved by switching the
truck off/on.
70-Component fails to
respond orresponds
incorrectly to self test
Regards
  • Posted 17 Feb 2013 08:02
  • Reply by nacsand_n
  • Madrid, Spain
edition #1235 - 19 June 2025
