Good morning/afternoon! (Depending on what side of the globe your on)
At unit start up, blank screen then error 0802. What is an 0802?
Measured all coils, all within 15-30ohms range.
Inspected wiring, no broken or loose wiring found.
Found cracked sensor on outter LS of mast.
Found open 9f2 slot (7.5a / 58v) fuse.
Switched with same rated slot 1f13 fuse, error code does not change.
This is my first jungheinrich, any help/ideas?
