Jungheinrich Etv 25 G 1999 error 42 Brake coil?
Hi , anyone know what this error mean ? It is a 1999 reach truck , no steer ,drive and hydraulic
  • Posted 4 Feb 2013 00:40
  • By gc_d
  • Zuid-Holland, Netherlands
Regards gc_d
Hi mate do you have any info on n this mod kit?
Regards
  • Posted 24 Jul 2026 17:38
  • By elektrodrive
  • joined 2 May'08 - 759 messages
enquiries@elektrodrive.co.uk
fine you solve it friend
Regards
  • Posted 12 Feb 2013 07:05
  • By nacsand_n
  • joined 20 Sep'09 - 714 messages
  • Madrid, Spain
Hi
Thanks friends for the info you have send to me , i found the problem , logic card steer and brake defective , but the led are green on the print ! I have replace them and set the cable of the brake coil exactly correct and teach in teh brake pot so it is fixed. Regards
  • Posted 12 Feb 2013 06:55
  • By gc_d
Regards gc_d
Hi all , thanks for all the info , i will check this and i hope i can fix it. i write the problem as i found it
  • Posted 5 Feb 2013 04:27
  • By gc_d
Regards gc_d
I once worked on an ETV reach, where it stated brake fault. I vaguely remember being able to reset brake pot?? I think. Is there this option on this truck?
  • Posted 5 Feb 2013 03:09
  • By elektrodrive
That's the one nacsand n, I remember it now - it was basically simple plug & play, just needed to fix the contactor down securely, I was sceptical at first but the mod kit sorted out the problems on my ETV trucks.
  • Posted 5 Feb 2013 01:11
  • By Forkingabout
  • england, United Kingdom
First you have to check the brake pads adjust, because the displacement of steel brake cable must be between 4mm (min) - 6mm (max).
Forkingabout is right, there is a service message about this fault. It's neccesary to install a small contactor and do a small wire modification.
Check your mail
Regards
  • Posted 4 Feb 2013 07:30
  • By nacsand_n
  • Madrid, Spain
Can you write serial of truck.Is it good your brake coil on the truck? Did you check wiring for brake?
  • Posted 4 Feb 2013 05:02
  • By nemanja_k
  • serbia, Serbia
  • By nemanja_k
  • serbia, Serbia
I vaguely remember fitting a mod kit to some ETV reach trucks a few years ago due to a similar brake fault.
They where around the same age as the truck you have.
  • Posted 4 Feb 2013 04:46
  • By Forkingabout
Héctor Guerrero Castañeda Héctor Guerrero Castañeda
Managing director, Jofson
CEO, Robust.AI
Zhejiang UN Forklift Co., Ltd
Phytoplankton create at least half of the world's oxygen production, despite amounting to only about 1% of the global plant biomass. They also respond rapidly on a global scale to climate and environmental variations, so are often used as indicators of marine health.
