JLG 20DVL "30 Error Code"
I have a JLG 20 DVL Axxessor that is throwing a "30" error code. "No comms - traction control module" Does anyone know what causes this error message. I know that JLG no longer uses this traction control module and has a new part number for it. The ground module says that the batteries need charged, but they are fully charged and have been load tested. I have completed the steps in the troubleshooting guide for this code and it says to replace the module. I hate to spend $1500 on a module if there is something simple I can replace on the board - resistor, relay, etc.
Thanks in advance for any advice you may have!
  • Posted 29 Dec 2014 22:53
  • By jon_d
  • joined 29 Dec'14 - 1 message
Rabbits can see behind themselves without moving their heads. Because their eyes sit on the sides of their heads, rabbits have an enormous field of vision that helps them spot predators from nearly every direction.
