IS THERE ANY JLG EXPERT???
Have a lift platform JLG 450AJ Series 2 Serial nº1300000213 year 2004.Have some manuals for this models but not including this serial number.I wonder if someone could tell me were is located the tilt sensor???Machine is always blocking and the 2 speed doesnt work.
I think is related to the sensor too.
Best regards
R.Feitor
  • Posted 9 May 2012 20:04
  • By feitor
  • joined 6 Jan'11 - 161 messages
  • Leiria, Portugal
my email: rc.feitor@hotmail.com
Hi Jplayer!
Thanks for your opinion.I realise that maybe theres no error in the sistem,it just needs to be tuned up.Tested the machine in a slope and in some positions the warning tilt light turns off.
Best thing to do is to get contact with JLG directly as you said.
Thanks for everything,
Best regards.
  • Posted 19 May 2012 02:04
  • By feitor
  • Leiria, Portugal
hello R.Feitor
yes i have been looking through the manual and this system is a lot more sophisticated than the normal JLG systems i am used to seeing. Yes i agree with you that the sensor is most likely located inside the ground control box or even possibly inside the platform control box. In the parts component sections for the base unit and also the platform control station i do not see any references to any type of sensors other than what you indicated by what is indicated in the electronic diagram/schematic. I suspect the sensor is located inside the electronic control.
As for error or warning indicators there is the light on the platform console that will flash MIL codes and also a light on the control board inside the ground control box.
If you need to pull codes from the ECM that can only be done with the handset or the PC version software. If there is a way to get the system to flash codes from memory i don't see any reference to how to accomplish this in the manual. You may have to call JLG and see if their service engineers can give you any pointers on any procedures that are not listed in the manual. Their engineers are good guys and will help if they can, i have dealt with them before in the past and they will help if they can.
  • Posted 19 May 2012 01:32
  • By Jplayer
John Player Jr
_________________
LiftOne, LLC
Charlotte, NC
Email: jplayer@liftone.net
That kind of sensor was what i was looking for,but this model doesnt have it!I think the sensor is located inside the GROUND CONTROL BOX(regarding a schematic in a manual).
This model has the ADE(Advanced Designed Electronics)and a green led(fault codes)in the ground control box.
My question is if this led flashes the codes or we can only read the fault codes with the analizer handset?
Best regards
R.Feitor
  • Posted 15 May 2012 19:01
  • By feitor
  • Leiria, Portugal
the tilt sensor is normally located on the base unit (turntable) inside the access doors, maybe on the hyd tank side. They are usually a cylindrical looking device mounted on a 3 spring pedistal. It will have a glass/clear top bubble indicator on top of it.
As for the 2nd (high) speed?
ANY boom or sizzor lift will not operate in high speed unless it is fully stowed away. If it is fully stowed then you have a switch malfunctioning.
  • Posted 14 May 2012 22:18
Hi Feitor,
Try www jlg com
Go to the service & parts section, click on the manuals box and you can download parts and full service manuals for all jlg trucks,
Pete
  • Posted 14 May 2012 05:58
  • By peter_d
  • joined 4 Jun'09 - 50 messages
  • manchester, United Kingdom
MAXAM Tire, Inc.
