Intermittent spark at operating temperature.
So this started with the lift not starting. Had a tech in, offered a full tune-up for several grand--tech suspected the propane regulator needed to be replaced. Rebuilt the regulator. Replaced the fuel supply shut off solenoid. (Found bad seals in both.) The lift would now start, but would not run long and had developed a miss. Threw a timing light on the coil wire, and instead of a steady pulse the lift had intermittent fire. (also determined there is a delay from beginning to crank to the coil actually firing built in from toyota) Replaced the cap, rotor, and plugs.
Lift now starts and runs great for 5 to 10 minutes, enough time to warm up to operating temperature. Then the lift begins to miss, the miss becomes progressively worse and eventually it dies and will not start until it's cooled down. It's emitting foul sulfur smelling exhaust--unburned propane. I am stumped.
  • Posted 22 Jul 2022 00:05
  • By Chappy
  • joined 21 Jul'22 - 1 message
  • Kansas, United States
Chappy, any update and/or solution to problem? I have the 7FGCU25 and just started having the same EXACT issue.
Ive cleaned the propane filter
Ran some seafoam through it
Disassembled the Regulator (Didnt find any problems)
Odd thing when it starts to miss, I can spray carb cleaner in and she runs fine for a bit (didn't try it with a load).
I have a new distributor set coming to try.
Any insight would be great as I'm just throwing parts at it now...
  • Posted 26 Oct 2022 05:18
  • By Zenonic
  • joined 26 Oct'22 - 1 message
Terberg RT223
SMV (Konecranes) 33-1200C
Stu Jacover Stu Jacover
Chief executive officer, TVH
edition #1285 - 11 June 2026
