Hyster w45z error
Fault codes 30016 and 30033 happens very often. Can't find the problem.
  • Posted 24 Oct 2019 03:48
  • Discussion started by alexmathey
  • Santa Fe, Argentina
alexmathey@gmail.com
First off you may want to double check your information on the machine, we'd need a full model number and serial number to give you accurate information on this machine.
I'm going to assume it's a HD series because the standard Z model comes with a zapi controller and the onboard manager does not display codes in the same fashion you are showing, zapi codes are different.
With that said here is what i can tell you based on the HD series where i found the same code syntax
code 30016
Are you sure about this code? It does not show up in the code chart
code 30033
Main contactor fault
possible causes:
- contactor coil wiring fault
- contactor coil fault
- faulty traction controller
  • Posted 28 Oct 2019 23:19
  • Reply by swoop223
can you send me the Serial # please.
Thanks
  • Posted 28 Oct 2019 08:39
  • Reply by John_Rogers
John Rogers
Toyota 8FD35U
Flesherton, Ontario, Canada
TCM FD115-3
edition #1235 - 19 June 2025
