Hyster W40Z display issues
Has anyone run into this problem. Fully charged the battery display shows 4 green lights. As the battery is discharged, it will only drop to 3 green lights. It gets to the point where error codes are coming up due to low battery but it still stays at 3 lights.
Have changed batteries, displays, control cards. There isn't anything left in the machine.
  • Posted 12 Feb 2009 08:06
  • Discussion started by Jmwhitti
  • Alberta, Canada
Hello! Try changing the charge Algorithm using the handheld. let me know.
  • Posted 21 Mar 2009 03:38
  • Reply by silvio
  • buenos aires, Argentina
EMAIL silvio_jorge@hotmaildotcom
check the wiring to the display. is the machine used on a rough floor. could be a break/make connection when going over bumps. pull every wire on every plug
  • Posted 11 Mar 2009 05:02
  • Reply by kevin_k
What zapi controller is in the machine?????
  • Posted 11 Mar 2009 04:32
  • Reply by DAMO
  • DUBLIN, Ireland
Yes it is the Zapi. All adjustments are fine and there aren't really too many the change with the hand held analyser.
  • Posted 11 Mar 2009 04:13
  • Reply by Jmwhitti
  • Alberta, Canada
Is this the zapi system hyster? I had similar issues with the ev100 system on the hyster E2.5 and 1.75. It was down to adjustments in one case and in the other case bad connections and a problem with the current sense wires which apparently hyster changed and resolved the problem. Dont know about this particular model will look into it
  • Posted 13 Feb 2009 19:59
  • Modified 13 Feb 2009 20:19 by poster
  • Reply by elektrodrive
Hangcha CPYD32XW71F-C
Flesherton, Ontario, Canada
SMV (Konecranes) 32-1200C
edition #1235 - 19 June 2025
Manitou MH25-4
Toyota 02-8FD25
UN Forklift FBT18NQZ1
Terberg TT223
Lift Tek Elecar
