Hyster starting problem
Working on A Hyster H60XM, 1999 model 4 cyl. GM on Gasoline. Truck runs great, plenty of power but very hard to start! a shot of either works everytime. put a tune up kit on it, nothing. checked the fuel pressure and only has 2-3 psi. fuel filter restricted, changed and pressure went to 4-5 psi. replaced pump and pressure went to 7-10 psi. , closed off return line and pressure went up 1-2 psi? Was told I need 35 psi?? can anyone render some help?? Thanks Alan
  • Posted 12 Oct 2010 04:14
  • By alan_h
  • joined 12 Oct'10 - 4 messages
  • Maryland, United States
That is what the vacuum line goes to correct? How do you trouble shoot it? Then of course how does it regulate the pressure and how would you go around it to see if it is faulty?
  • Posted 12 Oct 2010 11:52
  • By alan_h
hi Alan, have you looked at the Pressure Regulator?
  • Posted 12 Oct 2010 10:21
  • By steponmebbbboom
JLG G12-55A
Maxlion ESD15M
JLG G12-55A
Maxlion ESD15M
