Hyster E5.50 XL E120XL BDI
Hi,
I have a Hyster E5.50XL (E120XL in US) year 1999. The BDI (battery discharge indicator) is too low: it says empty when the battery charge level is more then 50%. It is the one ith 5 leds.
I have a PC cable with a 14 pole connector (only 3 wires attached). Do I have to connect this to the drive electonics (GE)? I have HYTECH software, but have no experience with this.
According to the manual I might need to change parameter 14.
Can somebody tell me how to adjust the BDI settings? The usage of this truck is very low, average 2 hours a week.
regards,
Frits.
  • Posted 19 Apr 2013 21:21
  • By frits_f
  • joined 19 Dec'09 - 320 messages
  • utrechte, Netherlands
je kan met de handset parameter 14 instellen van 0-100. Kijken waar deze op staat als je denkt dat de battery 50 % is.Dan moet je deze parameter aanpassen als deze een andere waarde aangeeft. 100 is vol , 19 is 30% , 9 is 20% dus slow lifting
  • Posted 27 Apr 2013 05:32
  • By gc_d
  • Zuid-Holland, Netherlands
Regards gc_d
Factory Cat MICROMAG20D
Nagano NUL120-6
