Hydraulic Pump 9229760025
The pump 9229760025 is out of production and i need to know its technical data to search a replacement pump. Anyone can help me, please?
  • Posted 11 May 2022 18:57
  • By pipeline
  • joined 20 Jan'13 - 6 messages
  • Lisboa, Portugal
look on the tag of the pump
go to the manufacturer and find that model pump
the white papers (spec sheet) should tell you
  • Posted 20 Jan 2023 06:00
9229760034 pump hydraulic
how many liters does this pump give if anyone knows ?
  • Posted 20 Jan 2023 03:36
  • By giorgos_k
  • joined 10 May'17 - 41 messages
  • Makedonia, Greece
look on the pump itself, it should have a tag on it with the mfg make and model and serial of the pump. try searching for it using that information.
chances are they just updated the pump to a newer model, it is unusual for mfg's to stop production of a part without having a updated replacement unless they discontinued the production of the whole lift. In most cases they usually use that pump in multiple models as well. Unless like i said, they updated to a newer model pump.
  • Posted 12 May 2022 20:28
Tusk 500PGH14
Kalmar-Ac P100CXD
Noblelift
