Hydraulic problem on mast operation.
When raising mast the 2 outer cylinders have started to lift first before main center cylinder.
Sometimes the main cylinder will start to lift first about 20 inches then stops and 2 outer cylinders will start going up.
Forks do not creep down when left up off ground.
What regulates the cylinders to make main cylinder lift first.
  • Posted 10 Jul 2020 21:55
  • By tdarr
  • joined 3 Dec'11 - 44 messages
tdarr@appi.us
Es probable que tenga fuga interna el piston central
It's likely there's internal leakage from the central piston
  • Posted 13 Jul 2020 12:10
  • Modified 13 Jul 2020 14:15 by administrator
  • By ikisleyva
  • joined 20 May'20 - 3 messages
  • Mexico
barbosa39314@gmail.com
I had a similar issue on a Clark. Ended up being a Cushioning valve.
  • Posted 10 Jul 2020 23:15
  • By Alvino_Revilla
  • joined 2 Jun'20 - 15 messages
