hydraulic oil in engine
Hello everyone I am a new member & looking for a little advice regarding a 1998 model toyota 1.50 ton forklift I am unsure what the model is but believe it is a 2 litre petrol.
This forklift has done only 600 genuine hours, I have only purchased it recently, I checked the dipstick a couple of weeks ago & found that it was overfull, I drained about 9 litres of oil out of it before it was down to the correct level, I checked the level on a daily basis for a few days & all seemed ok, anyway checked it today the oil in the sump seems to have increased to where it was a few days ago before I drained it prolly close to 15 litres of oil I noticed that the hydraulic oil is very low & believe the hydraulic is somehow mixing into the engine oil is this possible? or common what maybe the cause? there are no oil leaks coming from the machine at all. would appreciate any assistance thanx.
  • Posted 14 Apr 2010 20:25
  • By franko
  • joined 14 Apr'10 - 2 messages
  • New South Wales, Australia
Remember a poor man cannnot afford to buy cheap tools, it will always cost more in the long term
Hi mrfixit, I want to thank you for your response is this repair a difficult one as does it need to be done by a forklift mechanic or is it something that a person thats handy with tools can undertake? thx again
  • Posted 14 Apr 2010 21:01
  • By franko
The hydraulic pump is bolted on the right side of the motor and is leaking the hydraulic oil in to the motor oil. The seal is bad. The pump must be removed and new seals installed.
  • Posted 14 Apr 2010 20:37
