Toyota 42-7FGF15:
How to check oil pressure in hydraulic pump
Hi!
I have another short question. How I can check oil pressure in hydraulic pump? Forklift: Toyota 42-7FGF15. Is there any hydraulic pressure test port in this forklift where I can connect a pressure gauge and measure the pressure? I have a service manual but I can't find anything about it :( Please help.
  • Posted 22 Jul 2022 05:40
  • Discussion started by Lukas_Adams
  • Poland
Pump pressure is regulated by 2 relief valves in the hydraulic valve body for lift, tilt functions. Second is accessories. First pressure is main for lift and tilt. Should be around 2450psi. There are ports in the valve body to do so. Depends on your make of valve. If no ports visible. Remove 1 line of tilt on valve body and connect your gauge there. Remember safety with fluids. Once your gauge is attached you can get pump psi. Again type of valve body and relief valve is also needed to be known. Some have 1 relief valve but is stacked to adjust both primary and secondary psi. Others have upper and lower relief valve.
  • Posted 25 Aug 2022 21:25
  • Reply by ron_k
  • North Dakota, United States
4kliftman
Louisville, KY, United States
Dubuque, IA, United States
Hangcha FLDCXT160
Toyota 8FGCU25
Flesherton, Ontario, Canada
