Help to identify diesel pump for ordering purposes Fd15 DIESEL
Hi Folks,
We have a mbishi FG15 diesel machine presently in our workshop.
We are struggling to identify the diesel pump for this model would anyone be able to offer a hand?
The markings of the actual pump are as follows;
645L followed by a barcode:
cp723b 649a
Would appreciate some help or pointers in the right direction.
Basically the truck runs fine but does cut out after a few minutes all diagnostics so far point to the pump not supplying enough diesel.
Look forward to your much appreciate replys.
  • Posted 4 Apr 2014 02:42
  • By victor_d
  • joined 28 Aug'11 - 3 messages
  • Lancs, United Kingdom
Thanks guys for your insightful reply i will check the filter tank and lines as reccomended by alan and jim and will post my finding here.
  • Posted 8 Apr 2014 00:26
  • By victor_d
Check the fuel lines and the tank their is a gauze filter in the pump under the fuel in banjo also as their is no lift pump all in the injector pump we have fitted a electric fuel pump which helps.
  • Posted 6 Apr 2014 08:01
  • By alanmitsi
  • joined 8 Aug'13 - 151 messages
  • essex, United Kingdom
I have a couple of lifts that do the same thing.What we have found is the pick-up in the tank plugged.Engine runs a while then dies.Starts again then dies.Some mechanics blow thru line but that puts it right back into tank.Tank needs to be cleaned.We also have one that developed a fungus in the tank.That one also needs to be cleaned.We have been fighting that one for 15 years.You can put a suction line into clean fuel in a bucket and see if it works.That can at least eliminate the tank......Hope this helps.
  • Posted 4 Apr 2014 12:48
  • By jim_k
  • joined 28 Aug'08 - 21 messages
Hello,
Sounds logial do you have any tips on diagnosing this kind of fault on a diesel machine?
Thanks in advance
  • Posted 4 Apr 2014 04:23
  • By victor_d
if start fine dont look to the pomp more a fuel suplly problem of air in the fuel line
  • Posted 4 Apr 2014 04:06
  • Modified 4 Apr 2014 04:07 by poster
  • By AAPEE
  • joined 28 Aug'12 - 76 messages
  • Brussels, Belgium
Toplift Ferrari TFC36-48
Stoney Creek, Ontario, Canada
USD1
Taylor TX330S
USD159,500
VETTER Industrie GmbH
