HARSH PLUGGING
WE HAVE ONE TRUCK WITH HARSH PLUGGING WHEN GOING FROM REV-FWD. NOT THE OTHER WAY. HAVE CHECKED REC'S ALL OK, HAVE CHECKED CONTACTS ALL OK, HAVE CHECKED FWD AND REV SWITCHES-OK, CHECKED EV1 OSSILATOR CARD WITH A KNOWN GOOD TRUCK-OK
ANY SUGGESTIONS?
  • Posted 8 Nov 2011 03:34
  • By VAN_CEN
  • joined 8 Nov'11 - 22 messages
  • British Columbia, Canada
ahhhh
the old missing ball bearing torquing the drive unit scenario
dont ya hate it when that happens?
those are the ones that always seem to bite ya till ya figure it out
good job!
  • Posted 5 Oct 2012 00:01
Well a little info for everyone we finally found the problem the steer pivot bearing that the drive pedistal mounts through had one missing ball when you turned left the motor armature would torque into the field windings.Replaced the steer pivot bearing customer says unit has never run this well guess they had problem for a while so if you get this problem cheq that bearing even if unit steers ok
  • Posted 4 Oct 2012 12:11
  • By gary_r
  • joined 14 Dec'10 - 18 messages
remove the steering gearbox
jack truck up
try to turn drive unit left to right as if steering
should need hand strength to turn if shimmmed correctly
if you can turn with finger tips it is shimmed too loose
if you need to put your shoulders into it, it is too tight
from memory it should be 15 lbs using a fish weight scale to pull around
I will try to find the exact tension later
  • Posted 24 Apr 2012 18:13
  • By crownie
  • Victoria, Australia
how about checking the power cables to the motor
check the crimp on the terminals
maybe your loosing connection on one cable while in a turn
  • Posted 23 Apr 2012 13:43
  • By Jplayer
John Player Jr
_________________
LiftOne, LLC
Charlotte, NC
Email: jplayer@liftone.net
only turning left would make me think that possibly the battery is rolling
  • Posted 23 Apr 2012 08:46
  • By CGMI
  • joined 25 Nov'09 - 15 messages
  • Illinois, United States
Yes it does, even when the brake is completely removed the same problem is occurring.
when we dropped the drive unit only the top end was rebuilt. Has anyone heard of maybe the helical gear at the bottom binding under load? or in one direction of travel only?
just to reiterate, this is currently only happening when turning left (puf) and plugging the machine.
thank again for any help on this one, all ideas are welcome
  • Posted 14 Apr 2012 01:36
  • By VAN_CEN
this truck have an electric brake on that motor?
i'm just thinking outloud, dont mind me ;o)
  • Posted 13 Apr 2012 21:19
  • By Jplayer
John Player Jr
_________________
LiftOne, LLC
Charlotte, NC
this truck will be the end of me!
now the truck will do the same problem as before when making a left turn and plugging. WTF
any one?
i want to just say dont plug left
  • Posted 13 Apr 2012 09:47
  • By VAN_CEN
the lower support bearing for the drive motor is on the pinion shaft. removing it will replicate the problem, the fan will contact the motor housing. any other ideas?
  • Posted 10 Apr 2012 01:25
  • By VAN_CEN
How about taking the gear off the motor shaft and installing the motor back on the gearbox. Spin it up a little and plug it. If everything works ok than you have proved the problem is in the gearbox.
  • Posted 7 Apr 2012 12:19
Ok so I'm back in the same spot.
This truck is still giving the same symptom as last time. When I plug the motor makes a horrible noise (metal on metal) and stops the truck instantly.
the drive motor upper bearing, drive motor lower bearing on the pinion shaft and the upper drive unit bearing at the base of the pinion shaft have all been replaced, new shims and all, including the base plate.
When I swap out motors from one truck to another the problem stays with this truck,
The plugging diodes have all been changed out and aside from changing out the oscillator card I'm at a loss any ideas?
  • Posted 7 Apr 2012 07:48
  • By VAN_CEN
The upper drive unit support bearing is probably bad. It causes the drive unit to deflect and the motor fan to hit the side of the drive motor and lock up the motor. Recommended replacement on the bearing is 5000 hours, and less if you have rough floors or rail guidance.. If you see aluminum flakes around the bottom of the drive motor, that's the problem.
  • Posted 10 Nov 2011 14:09
  • By Liftdoctor
  • joined 22 Jan'05 - 115 messages
  • Indiana, United States
the 'poles' on the drive motor may need to be re-insulated and tightened down, if the field windings move at all, they can get a spot in the corner where they wrap around the pole shoe that can move and short to the frame of the truck.
  • Posted 8 Nov 2011 06:37
Terberg YT223
Toplift Ferrari TFC36-48
Stoney Creek, Ontario, Canada
USD1
Sue Tomic Sue Tomic
