Forks won't rotate
Having issues with the forks rotating. When rotating the thumb wheel about 10 degrees left or right the forks will rotate but very slow if they do move. If you go past 10 to 15 degrees they stop rotating and system sounds like it has gone into bypass. I have walked into issue after another tech has "worked" on it. He changed the pump thinking that was it. Then he replaced solenoid on valve just behind the mini mast. But doesn't remember which one. I began troubleshooting unit and deemed it was the rotator bypassing internally and started seeing oil at the base of the rotator. Performed learn on the truck and it will not complete. Truck has no codes. After the rotator was swapped out the unit did try to work briefly but has gone back to what it was doing before.
  • Posted 10 Apr 2025 01:36
  • By willj
  • joined 12 Feb'19 - 4 messages
will
edition #1280 - 7 May 2026
In this week’s Forkliftaction News , it’s financial reporting season with Hyster-Yale, KION Group and Konecranes all reporting revenue falls for Q1, yet maintaining their forecasts for moderate growth and stable sales volumes for the year... Continue reading
Rabbits can see behind themselves without moving their heads. Because their eyes sit on the sides of their heads, rabbits have an enormous field of vision that helps them spot predators from nearly every direction.
