Forklift repair
Code 215R No F/R or Hyds. ERP035THN36TE088 F807N04004D
  • Posted 13 Mar 2021 10:26
  • Modified 15 Mar 2021 08:31 by poster
  • By Prancer
  • joined 12 Oct'13 - 48 messages
berwinten@msn.com
Make sure the right motor brake is releasing. If you removed or replace the motor, make sure all cables were installed correctly. Check ohm reading from motor cable connections to frame, should not read. Make sure all cable connections from ESTOP, key switch, controllers and motors are clean and tight. When you have a code with an R or L, this usually means right or left motor or controller. Good Luck.
  • Posted 19 Mar 2021 06:18
  • By Fishmech
  • Virginia, United States
Updated with serial number.
  • Posted 15 Mar 2021 21:58
  • By Prancer
berwinten@msn.com
Do you have a serial #
  • Posted 15 Mar 2021 00:52
  • By forkliftpete
  • joined 19 Nov'14 - 24 messages
Bolzoni SpA (Group HQ)
SMV (Konecranes) SL37-1200A
Toyota 8FD45
