Toyota 7FGCU25:
forklift quit moving in both directions.
Forklift just quit moving both directions. You can feel trans engage in forward and reverse but makes a sound just like a spline shaft is stripped. Could it be shaft between trans and differential? Has anyone had or seen this problem? No noise or noticeable problem before this happened.
  • Posted 27 Aug 2016 04:16
  • Discussion started by tdarr
tdarr@appi.us
Mine did the same thing, manual transmission, thought I lost the clutch, pulled the engine and found the transmission input shaft has slid back into the transmission. I can pull it forward and it engages with splines in the transmission, but there is nothing to keep it from sliding right back into the trans. Right now I am trying to figure out how to split the trans and the differential. There must be some sort of keeper that let loose.
  • Posted 3 Sep 2016 07:37
  • Reply by Thor
  • Montana, United States
could also (more likely) be related to "inching" (far left pedal 'clutches" the transmission, if the actuator cable is binding, the valve spool in the transmission will not release the spool enough to allow the transmission to engage properly).
  • Posted 27 Aug 2016 22:12
  • Reply by edward_t
Taylor T650L
UN Forklift FD40T
Louisville, KY, United States
Dubuque, IA, United States
