forklift "Nichiyu"
Maybe someone know how to name, software for diagnosing forklift "Nichiyu"?
  • Posted 20 Feb 2013 18:03
  • By alexandr_k
  • joined 6 Dec'11 - 197 messages
  • Ukraine, Ukraine
Showing items 1 - 17 of 17 results.
my nichiyu forklift FBR is faulty and light is on p7 on the screen, can you help me please?. thank you very much! please help me!.
  • Posted 3 Jul 2022 18:59
  • By Vo_Huy
  • joined 3 Jul'22 - 2 messages
  • Viet Nam
Huy
Our controller had a nasty accident. The display backlight supply touched chassis and burned out a 74hct245 data buffer then sent high voltage down the ribbon cable to the controller board and burned out seval chips. I can replace all the chips but the eprom with the software is toast. If anyone could make an image it could really save my bacon. I used a very simple arduino project to read it. Three data lines stuck.
  • Posted 5 Jun 2021 06:01
  • Modified 5 Jun 2021 06:17 by poster
  • By JonoG
  • joined 15 Feb'19 - 77 messages
  • Uruguay
Jonathan Gill
Hi Marc. You might be able to help me, I have a Sumitomo-Yale 41-FBPVIII Forklift which has a Nichiyu PB83-90 controller. It was not responding and I found the backup battery was dead. I replaced it but now the display is throwing messages in Japanese. Is there a way to reset this board to factory settings ?
  • Posted 15 Jan 2021 00:34
  • By JonoG
  • Uruguay
Jonathan Gill
job well done Minh!
Regards
Marcb
  • Posted 27 Dec 2016 03:08
  • By marcb
  • joined 10 Jun'14 - 221 messages
  • ANTWERP, Belgium
Hi Marcb, thank you very much, the display board has worked
  • Posted 27 Dec 2016 02:28
  • By minh_d
  • joined 13 Jul'15 - 17 messages
  • Ho Chi Minh city, Viet Nam
duongminh6989@gmail.com
Hey Minh, the voltage on the back-up battery must be around 3,6 Volt. Just put the contact ON for a few seconds and put OFF again. If it works the machine is in it's factory settings.
Marcb
  • Posted 26 Dec 2016 20:41
  • By marcb
  • ANTWERP, Belgium
Hi Marcb, How voltage is the switch ON? 3V3 or 5V? When The switch ON need to hold how many second? Regards Marcb
  • Posted 26 Dec 2016 19:17
  • By minh_d
Hey Minh, You can try to do a reset of the display board. Connect the first and last pin of the 8 pins PC connector switch ON the contact switch and switch it back OFF, disconnect the first and last connection you've made and try again by switching the contact switch (don't do this with the other cards!!!). Have you bought an original back up batterry of Nichiyu?
Regards
Marcb
  • Posted 25 Dec 2016 18:56
  • By marcb
  • ANTWERP, Belgium
Hi marcb, The display board after replace a backup battery then don't working, LED cpu don't flash lighting, only LED P7 light. May you give me to repair in this case ?
  • Posted 24 Dec 2016 20:53
  • By minh_d
Minh, It can be programmed yes but it's just for factory and special requests.
Regards
marcb
  • Posted 24 Dec 2016 17:38
  • By marcb
  • ANTWERP, Belgium
Software connect with the cpu on the display module can the cpu reset ?
  • Posted 24 Dec 2016 14:34
  • By minh_d
two months in the repair of two forklift
One of them managed to repair. but during the repair of burned several expensive igbt modules-is very expensive experience.
but not even that the Problem, the Problem is that I can not guarantee that in the future I will burn more. even if I have experience in repairing. second forklift continues
  • Posted 23 Feb 2013 06:14
  • By alexandr_k
  • Ukraine, Ukraine
well a bit of a mystery for some.
Why are you so interested in it?
marc b
  • Posted 22 Feb 2013 18:31
  • By marc_b
  • joined 1 Jul'05 - 345 messages
  • ANTWERP, Belgium
some sort mystery...
even a scary...
  • Posted 22 Feb 2013 08:33
  • By alexandr_k
  • Ukraine, Ukraine
hey Alexandr, your right. It's just for changing the software on the display board and MPU-Board. If you have the software and you can connect it with your computer you have to learn Japanese. I have seen it used by a Japanese Technical person a few times, he could change the download speed of a forklift with fingertip control. He told me then that it could'n be used for testing any functions.
marc b
  • Posted 21 Feb 2013 05:28
  • By marc_b
  • ANTWERP, Belgium
ok thanks,
but even so, if there are connectors on the display module and the MPU module that means something must have?
  • Posted 21 Feb 2013 04:30
  • By alexandr_k
  • Ukraine, Ukraine
Hey Alexandr;
believe me there isn't software for diagnostics, there only a plug on the display board to connect a laptop for adjusting the software on the CPU.
kind regards
marc b
  • Posted 20 Feb 2013 22:14
  • By marc_b
  • ANTWERP, Belgium
Aichi RX07B
Rail King RK330
Aichi RX07B
Rail King RK330
Aichi RX07B
Rail King RK330
