Fiat DI40C
Hi
I have a Fiat DI40C 1998 model and my problem is that when I start up the truck drives ok but as it gets warm I loose the drive in both directions. Its got plenty oil in. Any ideas,
Has anybody got any pressure testing information IE pressures and test points.
Thanks
  • Posted 6 Apr 2012 06:38
  • By kevtwad
  • joined 5 Mar'11 - 76 messages
  • Northumberland, United Kingdom
First when you start up truck oil in gearbox must be on max after normally pressed gas and if you loose direction after worming truck problem is in gearbox and you must to open it.first step what you do is to open head of gearbox where are valves and to see is it something broken or stuck is everything is ok you loose pressure inside.You have mu mail in profile.Good luck it is a big yob.
  • Posted 7 Apr 2012 08:13
  • By nemanja_k
  • serbia, Serbia
UN Forklift FGL25T
Toplift Ferrari TFC36-48
Stoney Creek, Ontario, Canada
USD1
Muncie, IN, United States
UN Forklift FGL25T
USD1
