fault driving and lift
I have a h50, engine starts no problem ticks over nicely, when you try and drive or lift the revs will not build up stays on tick over so will not drive does anyone have any ideas many thanks
  • Posted 7 Jan 2025 01:40
  • By michael_johnson
  • joined 6 Dec'23 - 13 messages
  • United Kingdom
M johnson
Yes sir, glad you got it figured out
  • Posted 23 Jan 2025 03:53
  • By John_Bradley
  • joined 10 Aug'22 - 271 messages
Jb69
Thanks John i managed to figure it out it was the speed sensor as on our trucks when that sensor fails it normal bring up a fault code but it did not this time thanks for advise anyway
  • Posted 13 Jan 2025 17:34
  • United Kingdom
M johnson
Check the rpm sensor adjustment
The diesel will start and idle but will not rev
The lp or gas will not start
Are there any codes ? If no codes
Ck rpm sensor , seat switch ,brake switches
There are two switches on brake
One normally closed one normally open as I remember those items will give you that issue
  • Posted 10 Jan 2025 06:13
  • By John_Bradley
Jb69
Yes it does everything lifts/tilts just on tick over , it just wont rev up so then it will not drive, yes in the uk, we have a local company that we can get out just would rather have a go first, just its hard when we dont have the software to plug them in
  • Posted 7 Jan 2025 16:40
  • United Kingdom
M johnson
  • Posted 7 Jan 2025 16:37
  • Modified 7 Jan 2025 16:39 by poster
  • United Kingdom
M johnson
Does it lift or tilt at all?
If no it could be the seat switch, or could be throttle potentiometer needs calibrating/replacing.
Where are you in the uk?
  • Posted 7 Jan 2025 03:58
  • By andrew_k
  • joined 17 Mar'07 - 339 messages
  • England, United Kingdom
TCM FHD105Z
Toplift Ferrari TFC36-48
Stoney Creek, Ontario, Canada
USD1
