fault code e 27
what is this code
  • Posted 23 Sep 2009 04:45
  • By curt_s
  • joined 23 Sep'09 - 3 messages
I know this is an old post but also look for a misfire. while E-27 is a crankshaft position sensor code, it is often caused by a misfire from things like a bad coil, spark plug, tight valve, etc. It could be in the crank position sensor circuit but the misfire is a more common cause.
  • Posted 18 Mar 2011 02:04
  • By WMC1
  • joined 29 Oct'09 - 7 messages
Crank Position sensor.
How does the truck run?
If it won't start or goes into " limp home Mode" look at the sensor. if it runs poorly but you can rev up the RPMs check the plugs and coil packs.
  • Posted 23 Sep 2009 13:55
  • By roadtech
UN Forklift FD30T-NJM1
Ncn 110TH
Ncn 110TH 2015
Ncn 110TH
Ncn 110TH 2015
Esie Cortez Esie Cortez
