Fault Code 9 & 232 on Yale ERP040
Can someone tell me what fault codes 9 and 232 on a Yale Model ERP040THN36TE094 with Serial F807N02698C, mean?
Thanks,
OB1
  • Posted 7 Oct 2012 02:02
  • By ob1kenobi
  • joined 22 Nov'10 - 153 messages
  • SAN P.SULA, Honduras
Cheers!
gerardo_a is right
the alarm 9
FWD and REV SWITCHES CLOSED AT SAME TIME
Both the forward and reverse directional switches are closed at the same time
Probable Causes and Test Procedures
* Ensure all fuses are properly seated and tight in the fuse holders.
* Ensure all wiring connections are tight and secure at the fuse panel, key switch, and the battery disconnect switch.
* Check that the battery disconnect switch, the key switch, and the main contactor contacts are in the correct position and properly making contact.
* Either the forward or reverse switch is failed closed.
Use dash display diagnostic to check operation of directional switches.
Replace failed or malfunctioning switch.
* Directional switch is out of adjustment.
Switches should be open with directional switch in neutral.
* Wire #6 will be at battery voltage when the FWD switch is closed.
* Wire #8 will be at battery voltage when the REV switch is closed.
* Wires #6 & #8 will be at 0 volts when the switches are open.
Please recheck the alarm 232
not found in the manual
  • Posted 7 Oct 2012 21:45
  • By forklift_brasil
  • joined 27 Sep'12 - 55 messages
  • rio de janeiro, Brazil
tecmanuais@yahoo.com.br
skype:hyster.brasil
9 MEANS; F AND R INTERRUPTORS ARE CLOSED SIMULTANEUSLY.
THE F,R SELECTOR IS BAD OR A WIRE IN THE HARNESS IS BAD.
THE MANUAL DONT HAVE 232, ARE YOU SHURE IS RIGHT??
  • Posted 7 Oct 2012 15:39
  • By gerardo_a
  • joined 14 Apr'09 - 54 messages
  • United States
cgonzalez@indirep.com.mx
Hoist Liftruck P360-48
SMV (Konecranes) 16-1200B
Muncie, IN, United States
