fault code 100-4
We have a yale truck that has a fault code 100-4. It starts and idles fine, however it runs poorly, no power. Found a worn out crank timing pulley. Installed new pulley, belt and tensioner and can't seem to get it to run right. Hope someone can help. Thanks for your help.
  • Posted 28 Oct 2014 05:23
  • By cHarley
  • joined 9 Jul'14 - 15 messages
  • Oregon, United States
Thanks Nero, made some compared readings against a hyster with the same motor and got different measurements using an old pressure gage. The truck that runs good had 10psi idle - 15psi WOT. The problem truck runs 15psi idle and 25psi WOT@ 1900 RPM, Let throttle off and pressure went to 30psi motor stalls and pressure slowly climbed to 40psi. Starting to think it's a regulator problem. I know my gage will not be accurate, but the readings are too different to ignore and how do I adjust the pressure? Thanks Nero and have a good weekend.
  • Posted 1 Nov 2014 05:50
  • By cHarley
Set gas pressure to 5 psi
Nero
  • Posted 30 Oct 2014 20:02
  • By NER045
Nero, thanks for the info. Will look into it. I checked the fuel rail pressure, about 10psi. Is that the normal pressure? And what else could make this vortec 2400 loose so much power? Again thanks.
  • Posted 30 Oct 2014 07:48
  • By cHarley
Hi Harley,
All I can tell you about that code is that it is referring to the oil pressure sensor so that needs checking out also it's associated wiring.
The oil pressure sensor is reading low which may mean the sensor has shorted out or the wiring has. I would have thought the engine would have shut down within 30 seconds if that was the case still it needs checking out.
Regards Nero
  • Posted 28 Oct 2014 05:56
  • By NER045
The use of "hello" as a telephone greeting is attributed to Thomas Edison. He is said to have suggested it as a simpler alternative to other greetings, such as "Do I get you?" or "Are you there?".
Columbia, SC, United States
East Syracuse, United States
Saratoga, United States
Jeannette Walker Jeannette Walker
CEO, MHEDA
President, European Rental Association (ERA)
Chief marketing officer, JLT Mobile Computers
Komatsu FD25T17
UN Forklift FD25T-C2JM1
F. Uchiyama
edition #1237 - 3 July 2025
