FAULT 1123.6
hello, we have 1 efg 430K, the wiring harnesses and sensors are working properly, but I am waiting for your help in giving 1123.6 fault as soon as the parking brake is pressed.
  • Posted 30 May 2022 17:49
  • By emre_goren
  • joined 30 May'22 - 2 messages
  • Turkey
Hello, in most of my cases i had too change the valve block for the brake, part nr; 51415620.
It is wery hard too diagnose, when the brake is applied, sistem doesent get all the information in 1000ms, trigers the fault, than when you switch the machine off an on again, it is normal , until you step of the machine, and the brake is aplayed again.
Maybe these helpt.
  • Posted 8 Feb 2025 06:56
  • By Jooe
  • joined 8 Feb'25 - 1 message
  • Slovenia
As others have posted there are microswitches on motors that check brake response. They are replacable and adjustable. If your brake is old you may have to change brake coil or adjust microswitch.
  • Posted 30 Nov 2022 02:33
  • By Tanel_M
  • joined 18 Jun'22 - 90 messages
  • Estonia
check the left motor brake, it could be micros.
  • Posted 2 Jun 2022 03:44
  • By edmar_p
  • joined 18 Jan'13 - 49 messages
  • Guarulhos SP, Brazil
Edmar
hello, everything about the brake is fine, help with the control please
  • Posted 2 Jun 2022 03:30
  • By emre_goren
  • Turkey
if everything is in order with the brake, then the controller is to blame, you can contact me and help with the repair of the controller. This is a very common problem.
  • Posted 1 Jun 2022 19:41
  • By pavel_y
  • joined 27 Jan'16 - 52 messages
  • Donetsk region, Ukraine
Specialized repair of electrical equipment warehouse. Repair of controllers and components
check bremse on left side , connection or feedback switch on brake
  • Posted 31 May 2022 23:21
  • By tr_doctor
  • joined 4 Dec'20 - 186 messages
  • Netherlands
Regards
Toplift Ferrari TFC36-48
Stoney Creek, Ontario, Canada
USD1
Maxlion R2D25
GemOne
USD1
Maxlion R2D25
