Crown C5:
Event Code 0110.03
Any help on this would be great
Thanks
  • Posted 29 Aug 2023 01:30
  • Discussion started by Howitt
managed to come unplugged, plugged it back in. problem resolved
  • Posted 29 Aug 2023 06:22
  • Reply by Howitt
Engine coolant tempature signal is out of range (high).
Check the wiring to that sensor to ensure it isn't broken.
If it looks good then go into the service menu, analyzer, inputs, COOL_TMP, Enter.
If the senor or circuit has an issue, the screen will display ERROR.
If it does not display ERROR then the event code is no longer active. This sensor runs from the access 3 and does include a splice in the circuit.
Try testing the resistance in each cable in that circuit to make sure there isn't high resistance.
  • Posted 29 Aug 2023 01:40
  • Modified 29 Aug 2023 01:40 by poster
  • Reply by DyslexicNerd_01
  • Wisconsin, United States
Dubuque, IA, United States
Louisville, KY, United States
edition #1228 - 1 May 2025
