EV200 SCR CONTROL
Error codes: -095, -048 and steering motor starting with ignition key not with reverse. Is some one have idea were is the problem.
The truck is ELWELL-PARKER , model ESE 5.5. Ser.N: 27381
  • Posted 22 Jun 2012 22:50
  • By petko_t
  • joined 28 Sep'10 - 37 messages
  • Sofia, Bulgaria
p.troanski@abv.bg
Error 95 check brush of motor probably is brush sensor active error is seen when on TMM pin 11 and12 is 0v
Error 48 forward or reverse conttactor bad error is active when is t2 less than 12% of battery so check and her also.Good luck
  • Posted 23 Jun 2012 07:41
  • By nemanja_k
  • serbia, Serbia
Muncie, IN, United States
