EV100 pump and drive
Hello
We have a truck with a EV100pump ( P1) and a EV100drive (R2)controller.
When we use the pumpcontroller, the drivecontroller increase his speed and there is now traction anymore.
When you release the liftswitch the problem is solved.
There is no speed switch at the mast.
Whe changed the pump and 2 drive motors.
Is there someone who can help us
Cheers,
  • Posted 16 Nov 2010 06:38
  • By blackie
  • joined 9 Jul'06 - 52 messages
  • Gelderland, Netherlands
prajfa@hotmail.com
Hi blackie,
Does the truck lurch then fails safe or just increase in speed?
If it lurches forward and the fails safe then you may have an earth fault on the power part of the traction and hydraulic circuit check for an earth fault on the main thyristor on the EV100 traction controller (the power terminal that goes from the main thyristor to the direction contactor and also the bypass contactor if it has one). You may have a problem on the insulator under the main thyristor.
If it speeds up you may have a problem with the foot pedal wiring, MAKE SURE THE TRUCK IS JACKED UP OFF THE GROUND then check if the voltage on the TB1 connection on the EV100 traction logic with the foot pedal micro switch just made the voltage at TB1 (accelerator pot voltage) should be about 3.5 Volts then operate the lift switch and see if it reduces if it does you may have a short on the wiring between the foot pedal micro switch and the lift switch
Regards Shane
  • Posted 16 Nov 2010 19:00
  • By controlelectric
  • joined 8 Dec'08 - 70 messages
  • Shropshire, United Kingdom
It takes years to build up trust, and only seconds to destroy it. controlelectrics.uk@gmail.com
Terberg RT403
Taylor TXB180S
Terberg RT403
Taylor TXB180S
