Error Message F-01
I have a Unicarrier forklift M#MCP1F2A25LV S# CP1F2-9W2945 with 4800 hours. This forklift worked fine Friday and Monday it won't turn over. I can bypass the start circuit and it will start and run, but won't allow hydraulics or drive. A troubleshooting chart or suggestions would be greatly appreciated. Thanks
I've checked all the fuses, connections at battery, and vcm.
  • Posted 22 Jan 2021 09:52
  • By gw_e
  • joined 18 Mar'15 - 22 messages
gw.ebbs@deepsouthequipmentdotcom
Error code F-01. VCM Memory Check. Condition- EEPROM check sum, Controller type not matched. Action- Control module stops operation (only executes CAN communications)
I will update if I find any trouble shootimg tree. Can only find the code description right now.
Id check all the grounds for clean connection. The one by the vcm and the one on Lh side as well. Also check power and grounds to your vcm connectors. But sounds like a VCM issue. Could swap in a known good vcm if you have a similar 1F2 truck around.
  • Posted 22 Jan 2021 10:26
  • By BLey
  • joined 31 Jul'20 - 60 messages
Taylor THC500L
Airman ENCL045
