Raymond 470 C50:
Error Codes
Anyone have the error codes for a Raymond electric 470? I keep getting 86,08,64.
  • Posted 26 Jan 2023 09:07
  • Discussion started by Fusion
  • British Columbia, Canada
Code 86: Traction Potentiometer
Out-of-Range
Traction Pot is outside the learned
voltage range. This code can also be
displayed if there is no power to the
TPA or if one of the power cables to the
traction motor(s) is open.
If code is displayed in conjunction with another code,
troubleshoot per that code. Verify battery voltage. If wrong
voltage, set correct voltage via FlashWare (and re-Learn
pots) or install correct voltage battery. Check both
traction motor encoders, temperature sensors, and
connections. Check power to the TPA. Check the power
cables to the traction motor(s). Check pot voltages. Check
resistance of resistor in static strap standoff; should be
200 to 250k ohm. Verify configuration jumpers are in
place on PPA. If OK, run Learn. If not OK, replace the pot.
  • Posted 7 Apr 2023 08:18
  • Reply by Ironman_93
  • Argentina
thefixerman.service@hotmail.com
Had the unit repaired. 86 seems to be a motor controller board failure. This set us back over $10K. Good little unit but parts are hard to come by and very expensive.
  • Posted 7 Apr 2023 01:08
  • Reply by Fusion
Quizas pueda ayudarte escribime
  • Posted 31 Jan 2023 13:38
  • Argentina
St. Louis, MO, United States
Johnston, IA, United States
Jefferson, WI, United States
Toplift Ferrari TFC36-48
Stoney Creek, Ontario, Canada
USD1
Aichi RX07B
Noblelift
Hangcha CBD15
China
USD1,600
Manitou MH25-4
edition #1234 - 12 June 2025
