Hi,
I have a Stand up Raymond forklift with deep reach. Lately, it started showing error codes like Code F4, Code F5, Code L1... Does anyone know from where I can get a list of these codes with explanation?
Best regards.
G3 looks like ur proximity sensor can be damage. 44 and 2U is your motor wires that connect to traction amp and you also will need a traction amp.
Dear Sirs,
Hope you help me because i have big problem with electric forklift OM XE 15 3AC. There is error code 64 and 120, also 245. Please send me some info what are meaning this codes and how can i repair it. The machine works like turtle and after 3 meters - power off. On the display there is 64 error code. Please send me some info.
Hope you help me. Thanks in advance and Best Regards!
Hi there guys. Met with some error codes on Raymond reach trucks. Can someone share the manual or give some light to the error codes on Raymond
error code G3, G5, 44, 2U
Have no access to the code manuals.
Thank you guys
BT Cargo CBE25 s/n CE233085
Need help with error code 59
Аnd yet I'm looking for a service manual for this forklift and if so, error codes
need help with error code E Ad-1 lift will not start
cat model n0r30
s/n 2m6-00182 i dont have the battery i thin is 36 but the code i have is code 80
give the model and serial number of truck, maybe i can help you the voltage and battery capacity thank you,
I also have the same issue with a code F5 on a reach. The model is a EASI and serial number is ET-B-94-00986. This unit is a 24 volt system.
It turns on, and goes through the testing cycle, then it codes F5. I notice both contactor tips are fairly burnt and they both pull in, but after 2 to 3 seconds of it pulling in, it codes out.
Anyone has any suggestions or what this code means.
Thanks.
As a former Raymond tech I understand your problem. Do you still have the problem or has it been solved? Before I anger the Raymond Gods of Forklifts by giving out private information. Understand Raymond is very proprietary and defends their territory. Hopefully Toyota will help them become more service friendly.
for the toyota the BT i am not shure i will keep my ears open
Ok looks like u have a communication problem between the SCPU and The CPU. Does the truck have SAS? Check the PS contactor next to the F3 Fuse if that contactor dose not pulls in quick enough it will cause that code do u have a wire diagram? because if its not that contactor u will have to check voltages between the CPU and the SCPU sounds like a wire break but may be earthier the CPU or the SCPU
Anthony, You must give Model and Serial # for all questions asked. It's like asking, do you have a stater motor for a FORD Vehicle. Giving us that information will help us help you
if youre a tech
raymond will sell you the book (theyre actually not horribly expensive i think i paid 85 for mine)
then youll have to pay them a service fee to come out and reset the PW or you can change the eprom (i forget which but theres a hardware swap that will default the PW)
id imagine hes working on an EASI reach
Greetings, What is your model #?
