Error code Jungheinrich
Hi our reach truch gets error code 7 and comes to a stop.
Does anyone know what generates this error so we can fix the problem?
Maybe someone has a list of codes or a shop manual?
The truck is a Jungheinrich ETV114 model.
  • Posted 11 Jan 2010 09:54
  • By blaster
  • joined 11 Jan'10 - 2 messages
  • Queensland, Australia
Thanks for the help everyone - yep its probably a dead cell.
It drives until the lift motor is engaged, then the error comes up and drive stops.
Cheers
  • Posted 12 Jan 2010 10:32
  • By blaster
Error 7 is for the key switch being turned off while in opperation but it is almost always a battery voltage problem. Try driving the unit while tilting back (ie have the battery under load) and see if the fault appears. Also check the battery voltage at the same time. You will probably find the the voltage is dipping under 35V. If it does load test each cell and see if there is a bad one or see if the whole battery is stuffed.
Cheers.
Matt
  • Posted 11 Jan 2010 22:37
  • By BEST
  • joined 27 Feb'08 - 10 messages
  • New South Wales, Australia
HI Blaster.
Code 7 could be the keyswitch or low voltage. I've also seen this error by defective interface card (voltage measurement) on controller. Do you have serial number / year?
Regards, Max
  • Posted 11 Jan 2010 18:06
  • By Fittermax
  • joined 17 Jul'08 - 171 messages
  • Denmark
Thank's for helping. Contact d-b-a@mail.com
P i s s Work, gone fishing
TCM FHD105Z
Maxlion FB25EH
GemOne
TCM FHD105Z
Maxlion FB25EH
