error code E62-1 and E09-1
Have a 8fgu30 throwing codes e62-1 and e09-1. Can anyone tell me what these are for?
Also same lift truck is not starting. Only getting fire when key is in accessory mode but not when start mode. Have tried changing key switch, ecu, and checked wiring harness with no luck. Any help?
  • Posted 26 Feb 2016 03:17
  • By lee_r
  • joined 26 Feb'16 - 1 message
  • Louisiana, United States
First code not related. Second code is ignition circ issues. Check for broken wires at distributor harness plug. Check ign coil, igniter module and ecu.
  • Posted 27 Feb 2016 13:28
  • By BartTech
  • joined 2 Nov'14 - 8 messages
Rabbits can see behind themselves without moving their heads. Because their eyes sit on the sides of their heads, rabbits have an enormous field of vision that helps them spot predators from nearly every direction.
