Error Code E40
Hi Could any one help with this.
Turn machine on runs through self diagnoses check and then comes up E40 error message.
  • Posted 31 Mar 2017 06:12
  • Modified 31 Mar 2017 06:13 by poster
  • By Brad43
  • joined 11 Oct'12 - 23 messages
  • New Zealand, New Zealand
Anyway I could get one of you fellas to forward me that diagram. I'm in a pickle here and probably out of my depth with one of these battery powered lifts.
  • Posted 28 Oct 2024 17:48
  • By Will_McCrary
  • joined 28 Oct'24 - 2 messages
Hi Mark
Thanks for your help on this matter. Would you have a wiring diagram for one of these units by any chance?
Regards Brad
  • Posted 7 Apr 2017 05:02
  • By Brad43
Hi Marc any luck with some manuals etc?
  • Posted 4 Apr 2017 08:29
  • By Brad43
brad @ ecrl. co. nz
  • Posted 1 Apr 2017 08:15
  • By Brad43
Hey Brad, put your email in your profile or send me one I will take a look.
regards
marcb
  • Posted 1 Apr 2017 08:06
  • By marcb
  • joined 10 Jun'14 - 222 messages
  • ANTWERP, Belgium
Hi Marc, Would you have or can you get hold of any workshop manuals , faulting finding data or test procedures for one of these units.
Regards Brad
  • Posted 1 Apr 2017 07:57
  • By Brad43
Hey Brad, yes it would (not for the red emergency switch) but for the solenoid. I had a year ago the same fault on 1 solenoid (it distroid the MPU-Board) and have to change the complete hydraulic valveblock and MPU-Board. Do measure the resistance on all solenoids and see what the differance is.
Regards
Marcb
  • Posted 1 Apr 2017 07:06
  • By marcb
  • ANTWERP, Belgium
Thanks Mark will check this out on Monday. Would this cause the main contactor to kick out straight after the key is turned on?
  • Posted 1 Apr 2017 06:22
  • By Brad43
Hey Brad, looks like you have a problem with a solenoid valve of the hydraulics.
detected valve input value >=4,15Volt
detected valve input value >=0,49Volt when hyd. lever OFF
detected value input value >=0,49Volt when hyd. lever ON
also look at the red emercency button.
Kind regards
Marcb
  • Posted 1 Apr 2017 00:10
  • By marcb
  • ANTWERP, Belgium
Komatsu FD25T17
Taylor T520S
