Error code e159
Tried to use pallet jack and got error E159 and nothing works does anyone know what this code means?
  • Posted 31 Dec 2021 01:09
  • By Daveyboy
  • joined 31 Dec'21 - 1 message
David tennant
It is the code of just about everything. Can communication error. So several things involving this code. Have the same error on one now and never thought it to be a E-tac issue. But here's some others to check before. First is the red toggle switch.
Make sure it's good. If you have
the keypad, you will have to code
in also to power up if not
disabled. Next is line contactor
coil voltage. If low use toggle on
and off to watch voltage. If every
time it increases, then it's the
lithium etac battery and the card
or battery must be replaced. Is
the gray cable going to the etac
card ok. Also a issue and has a
upgraded part out for it.
Updated repair! First remove the handle controls, and check the lithium battery on the etac card. If below 3v. It has to be replaced. You can just replace the battery for about 5$. Easy to remove and soldier back on. Remember you are working with a battery and heat for the risk!
  • Posted 11 Feb 2022 00:18
  • Modified 17 Feb 2022 23:21 by poster
  • By ron_k
  • joined 2 Apr'15 - 111 messages
  • North Dakota, United States
4kliftman
edition #1238 - 10 July 2025
Cleveland Ohio, United States
Wentzville, MO, United States
Columbia, SC, United States
Zhejiang UN Forklift Co., Ltd
Laura Ness Owens Laura Ness Owens
Chief marketing officer, Bobcat Company
Chief commercial officer, Teradyne Robotics
CEO, MHEDA
President, European Rental Association (ERA)
Crown WP302020
Mitsubishi FGE35AT
Bolzoni SpA (Group HQ)
The dot-com bubble, a period of large and rapid investments in internet-based companies, peaked in 2000 and saw the Nasdaq Composite index rise by 579%. Then the bubble imploded. As the value of tech stocks plummeted, cash-strapped internet start-ups became worthless and collapsed.
