error code 751 flashing
Flashing code 751.I need help with this code and what to check for?
  • Posted 10 Sep 2015 02:01
  • Modified 10 Sep 2015 02:02 by poster
  • By greasespoon
  • joined 30 Jul'09 - 154 messages
  • somerset, United Kingdom
So no air through either side right?
  • Posted 23 Feb 2022 09:46
  • By Jose_Felix
  • joined 11 Feb'22 - 1 message
Check for Vac. leaks, and the Fuel Trim Valves. You can Ohm them out should be 26+/- 2 ohms. If you can blow air through them then they are faulty and stuck open.
The fault code reads as Pre-Catalyst 02 sensor indicates extended lean operation. This is odd as the system is designed to run rich when something goes wrong with the fuel system.
  • Posted 5 Oct 2017 23:15
  • By sirthor1881
  • joined 15 Mar'11 - 24 messages
Terberg RT403
JLG G12-55A
