Yale OS030EFN24TE089:
Error Code 30116 Traction Encoder Mismatch and for another picker its NODE 2 25350
Hi All
We have 2 Order Pickers one with error code 30116 Traction Encode mismatch. No up and down no forward or reverse.We check the switches the connection everything's okay.
Could you guide me where to look or how to fix it. I'm thinking its the controller the ACE0 but supplier said that rarely breaks.
2nd picker can go up and down and no forward or reverse.
error 25350 NODE 2.
  • Posted 13 Aug 2018 07:50
  • Discussion started by justine_q
  • Guam
Hello,
I have the same problem with a Hyster order picker. I have the service manuals and the Service tool, however, I have not been able to find how to reset the height encoder value. It reached the maximum height (370") and then it got the Hydraulics Disabled error code. It was manually lowered, now it is shown the error code 30116. Does anybody know how to reset the Height Encoder Value ?. Thanks !.
  • Posted 24 Oct 2022 03:36
  • Reply by jorge_z
  • Coahuila, Mexico
jorgez357 at hotmail dot com
For the second code you can try lifting the mast above 30" then lower to floor, If this resets it the problem was in shut down truck before fully lowering, if it does not then there is a problem in wiring or a component.
  • Posted 13 Aug 2018 22:38
  • Reply by BREWSKI
Both codes are for a problem with the height encoder and the mast prox. switch. You need the service manual to do a reset on the height encoder. In most cases this will clear the problem.
There is a mismatch condition between the mast prox switch and the height encoder.
  • Posted 13 Aug 2018 22:30
  • Reply by BREWSKI
Scott Young Scott Young
Head of Sales North America, Volvo CE
Vice President of Sales, Tompkins Solutions
Chief Operating Officer United States and Canada , Swissport
President, Volvo Penta
Hyster-Yale Asia-Pacific Pty Ltd
We fully support a range of lift trucks from design to service, primarily under the Hyster® and Yale® brand names.
