error code 3.587
We are having some problems with a BT LPE200.
It runs fine for 5 minutes or so, and than suddenly stops.
error code 3.587 is in display.
By turning the machine off and on the error will disappear.
After a few minutes of work, the same error will appear and machine will not drive or lift.
I believe it happens during slowing down, releasing the leverhandle.
somebody with an idea, or even better: an error codes list????
  • Posted 13 Aug 2019 07:07
  • By henli
  • joined 24 Jun'15 - 5 messages
  • noord brabant, Netherlands
Thanks for your reply.
I had the voltmeter plugged into the battery cables during testing.
there was no change in voltage, a good 24 vollts.
I will clean the battery connectors,and look for bad connections in the machine.
Good to know what i am looking for.
thank you.
  • Posted 15 Aug 2019 22:38
  • By henli
Battery voltage exceeds 33 V
Truck behaviour
Everything is stopped at once,
the parking brake is activated,
and the main contactor opens
Voltage loss on supply to T1
* Battery defective
1) Check battery voltage
Check the voltage using
the built-in test procedure
and comparing with
value from external volt
meter
Check connectors, joints
and splices for damage
or corrosion.
Check fuses F1 and F50
2) Inspect the battery.
  • Posted 14 Aug 2019 19:04
  • By Roibeard
  • joined 2 Mar'10 - 335 messages
  • Dublin, Ireland
Sue Tomic Sue Tomic
Aichi RX07B
Toyota 8FD45
Sue Tomic Sue Tomic
