error code 21
please help, I have an error code 21, full functions on my jack except no lift. I usually only work on pe 4500 and only have those manuals. I've already tried changing the solenoid, no issue there.
  • Posted 12 Aug 2018 15:29
  • By fonny02
  • joined 12 Aug'18 - 1 message
  • Connecticut, United States
You probably indexed the traction pot at the incorrect spot. Raise drive tire off floor with jack and move pot away from throttle gear. Then with handle down and brake switch closed hit one of the travel switches while reindexing the pot and then make sure it does not move. It may be correct but if it was normal speed before and now super slow, I would check that. Is the jumper wire correct on the pot?
  • Posted 19 Nov 2021 14:10
  • By 1CrownTech
  • Washington, United States
1crowntechnician@gmail.com
Q tal buenos dias
Tengo problemas con este equipo pe4000 alguien tiene el esquema eléctrico
Saludos
  • Posted 19 Nov 2021 06:34
  • By Carlos_Gomez
  • joined 20 Mar'20 - 16 messages
  • GUAYAS, Ecuador
Carlos Gomez
On the side of the lift motor
  • Posted 25 May 2019 21:29
  • By popeye
Where is that located?
  • Posted 20 May 2019 06:40
  • By troy_a
  • joined 5 Apr'19 - 21 messages
  • Arkansas, United States
Check the pressure transducer. If the truck thinks you have it overloaded it will only let you run at slow speed.
  • Posted 20 May 2019 03:53
  • By popeye
I replaced the potentiometer and now no codes but it moves like it is in limp mode. Any ideas?
  • Posted 10 May 2019 01:31
  • By troy_a
I had the error code 21. Put a new potentiometer and now no codes but moves slow. Any ideas on what to check?
  • Posted 10 May 2019 01:29
  • By troy_a
I have the same code 21 and everything works but in slow motion. Can someone help?
  • Posted 24 Apr 2019 03:37
  • By troy_a
Hi popeye so I'm running into same code same model Chuck is traveling slower than normal but that's all I pretty much notice did you find a resolve to this situation what did you end up doing is it the contact er's? Please let me know if you can
  • Posted 13 Dec 2018 01:01
  • By jake_w
  • joined 5 Dec'18 - 4 messages
  • New Jersey, United States
#21 will not disable lift it is for accel potentiometer and may keep you from having high speed but that is it. Is the truck in lift lock out? Is the solenoid energizing and suppling power to motor. Are the brushes in the motor ok?
  • Posted 13 Aug 2018 00:21
  • By popeye
